How I can determine ripple voltage in full wave rectifier circuit ?
Discussion in 'General Electronics Chat' started by Radoi, Jun 3, 2010.
  1. Radoi
    May 3, 2010
    hi guys
    I have problem when I wanted design DC power supply
    ( I used
    center tap full wave rectifier with smooth capacitor and zener diode )
    that problem is how I can determine
    ripple voltage to find capacitor value ?
    I have following values
    - output voltage = 4.7 V
    - input voltage from transformer = 9 V . " Is it peak or RMS value ? "
    -load resistance = 100 Ω.
    - frequency = 60 Hz .
    I asked my friend , he told me you can assume it (
    ripple voltage )
    but how I can assume it ?? is there certain range for assumption ??
  2. Bychon
    Member
    Mar 12, 2010
    469
    41
    √2 C Er F = I
    The square root of 2 times the capacitance times the Ripple voltage (peak to peak) times the frequency equals the load current.
    and the frequency is 120 for a full wave rectifier.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Where did the √2 come from? A conservative estimate for ripple voltage of a full wave rectifier is
    Vr=I/(2*F*C)
    where F is the input frequency. The "2" comes from the frequency doubling of the full wave rectifier. The calculated ripple will be very close to the actual value when the ripple voltage is a small percentage of the peak input voltage. As the ripple percentage increases, the equation becomes less accurate, but the ripple will always be less than the value predicted by the equation.
    BTW, this assumes that the input is a sine wave.
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    Sorry, radical2 CErF=I isn't a conservative estimate. I don't know where I picked that equasion up, but it produces results that match my measurements of real parts that are actually working.
  5. Bychon
    Member
    Mar 12, 2010
    469
    41
    Voltage Regulator Handbook
    National Semiconductor Corporation
    1982
    Page 8-6
    Paragraph 8.2
    Line 4
  6. kingdano
    Member
    Apr 14, 2010
    377
    19
    what would those guys know anyways?
    :rolleyes:
    :D
  7. Bychon
    Member
    Mar 12, 2010
    469
    41
    LOL! It might not be pretty, but it's functional.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    I'm not sure the contributions thus far will fully answer the OP's question or lead them to think about the problem more broadly.
    They are considering the design of a centre-tapped transformer, full-wave rectifier with zener regulated output. The question seems to centre on choosing a suitable rectifier filter capacitance. So what are the considerations in making an informed choice?
    It's not clear whether the OP's problem is with the observed ripple on the output [at 4.7V DC] or the ripple on the rectifier section output. Do they have to meet a maximum allowable load ripple condition?
  9. Bychon
    Member
    Mar 12, 2010
    469
    41
    Perhaps you can ask the O.P.
    As for me, I've been wondering if "drive by questioning" is a familiar phrase in these forums.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    I get your drift. I guess that's the nature of the 'game' we play.
    We would possibly get bored if it were otherwise ..... and a bit of friendly banter is part of the fun of being here.
  11. Bychon
    Member
    Mar 12, 2010
    469
    41
    Banter away my friend!
  12. Radoi
    May 3, 2010
    Thanks my friends
    I solved my problem ..
  13. Hell_Bent_On_Sumthing
    Sep 2, 2014
    AAAAHHHHAAAA!!!!
    Has to do with RMS value
    I was looking for an equation to find out how much capacitance in needed in my supply
    the radical2 comes from frinding rms values Vpp/rad2=Vrms
    Why one is an approximation and the other is exact math
    ps. this thread has also enlightened me that keeping I and C the same, you get the same Vr regardless of the voltage
