How hard to convert this sketch to be used with a different sensor
Discussion in 'Embedded Systems and Microcontrollers' started by james211, Feb 4, 2014.
  1. james211
    May 29, 2012
    210
    So I have a sketch that works very well, its a water level sketch using a URM37 ultrasonic sensor. The problem with using that sensor is they are no longer available in the US (DFRobot has them, but they ship from China). I would like to be able to use this sketch with a different ultrasonic sensor, but I have no clue how hard it would be to convert the entire sketch to use a different sensor.
    Would anyone be willing to take a look at the sketch for me?
    My biggest concern is that these sensors don't seem to be designed to be in a humid environment so the rate of failure is higher than other sensors. Ideally I'd find a system that maybe uses differential pressure as those sensors seem to more stable under humid conditions for long term. Agree or disagree?
    In the end I need to be able to monitor the depth of the tank remotely. With my current setup I can see it from anywhere either via the built in server on my network or via Xively, it works very well!
    Thank you!
    D
  2. inwo
    Nov 7, 2013
    2,435
    315
    Can you post the pertinent sketch?
  3. james211
    May 29, 2012
    210
    It's attached to thread as a zip file.
  4. Alec_t
    Sep 17, 2013
    5,976
    1,136
    People don't trust zip files :(. Post as a .gif or .png.
  5. james211
    May 29, 2012
    210
    Good to know! It's a multi-page so I figured that was the best option. I'll have to post each individually then...not sure it will let me attach that many in fact.
  6. inwo
    Nov 7, 2013
    2,435
    315
    Isn't there just one that covers the basics?
    Saves time.
  7. james211
    May 29, 2012
    210
    Here are the basic code pieces.
  8. james211
    May 29, 2012
    210
  9. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
  10. BMorse
    Sep 26, 2009
    2,675
    234
    for one the URM37 has its own built in arm processor, it is basically a standalone unit that interfaces to other uC's or a PC through serial communication.... those other ultrasonic sensor modules still require a uC to operate them and do all the data conversion to get the distance measured...
    Why not get an Arduino UNO or something similar to connect these ultra sonic modules to?
    http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor
  11. james211
    May 29, 2012
    210
    I am connecting it to an arduino uno!
  12. BMorse
    Sep 26, 2009
    2,675
    234
    Well, there you go, looks like a whole sketch has been written already for you, :)
  13. james211
    May 29, 2012
    210
    Well I already have a sketch written that I like, I just want to know how hard it would be to replace the current sensor with a new sensor on the current sketch.
  14. BMorse
    Sep 26, 2009
    2,675
    234
    Unfortunately, the first module you mentioned is controlling the ultrasonic transducers itself, there is no "driver" circuit, so if you want to "copy" that first module, the other 2 you mentioned wont work, you will have to get some ultra sonic transducers and re create the circuit to drive them.
