how far max232 can travel
Discussion in 'The Projects Forum' started by sasek, Feb 19, 2010.
  1. sasek
    Jan 3, 2010
    64
    im using max232 2 make connection betwen PIC and PC, here i want using max232 to make far connection betwen both of them. The problem is, i dont know how far data can go with max232 without repeater like max485........someone pls help me about the distance max232 can go........:)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    How far do you need?
  4. sasek
    Jan 3, 2010
    64
    i want used about 100m. Mean that max232 and rs485 almost same in function???
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Too long for RS232. RS422 & RS485 can do that distance.
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I could be wrong, but I think RS-485 and LVDS are two entirely different things.
  7. DickCappels
    Aug 21, 2008
    2,753
    665
    I had one that traveled nearly 14,000 miles. How did this happen? The first 8,000 miles was in my luggage from the U.S. to Thailand, and the next 6,000 miles was by express mail from Thailand to Scottland.
    More seriously, the MAX-232 should work fine over a distance of 100 meters if you use a low enough data rate. The type of wire (mostly the capacitance between the conductors and the resistivity per unit lenght) will have a lot to do with the maximum data rate.
    One thing to be aware of is that with longer runs, you will increase your chances of data corruption from noise sources and you will increase your chances of damage from nearby lightning, so use appropriate precautions.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes. RS-485 uses differential signaling, but the LVDS standard is distinct from that. Should have said that RS-232 is single ended, and RS-485 is differential.
  9. sasek
    Jan 3, 2010
    64
    i still confius, so what i suppose to do???? the circuit of rs485 is quit difficult to understand
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We are also confused.
    Until you give some idea about the separation in the "far connection", we have no idea about the distance.
  11. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Are you kidding? RS-485 uses a differential signal bus, and the transceiver chips provide you with a transmitter and a receiver. You do need to terminate the bus at each end. It is not full duplex, but you can go further than 25 ft. or 10 m which are the two rules of thumb for maximum distance on RS-232 at low to medium baudrates (1200-19200). You also did not mention how fast you want to go.
  12. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You could use RS422, this is very easy to implement as a RS232 replacement for long distance bidirectional communications.
    www.rs485.com has several adapters, schematics etc...
  13. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Point is that none of these methods should be a source of confusion since they are all implemented with COTS(Commercial Off The Shelf) transmitter/receiver/transceiver chips. The datasheets have typical operating circuits and the manufacturers application notes make using them a cinch. I don't know where the confusion comes from. Can 'ya 'splain it to me one more time, cuz I'm just a poor old country boy without 'yer book larnin.
  14. sasek
    Jan 3, 2010
    64
    hahahahah thanks 4 helping
    did max232 and rs485 work in almost same concept
  15. retched
    Dec 5, 2009
    5,201
    313
    Yes, they both use wires.
  16. t06afre
    May 11, 2009
    5,939
    1,222
    Just a few words. For better understanding of the circuits read abou or Google RS232 and RS485. Then take a look at the voltage specifications. Also how do plan to connect your RS485 signal to your RS232 serial port input?
  17. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    And we still have no idea at all about the dimension of "far distance".
