CAN U EXPLAIN about DUAL diodes functioning in the above circuit please...The diode served a different purpose here. It is not an extra but essential instead to provide separate paths for the positive and negative feed into voltage clamp.
It has to be connected like that because the LM311 has open-collector output so it cannot source current but can only sink current. Without the diode the path would be +15V into 2x1K2 in series for positive feed whereas the path is -15V via a single 1K2 for the negative feed to the voltage clamp.
I have highlighted the two different paths in the diagram so you can better visualise the process.
