How Does One Find An Equivalent Component?
Discussion in 'General Electronics Chat' started by snarf, Jun 26, 2008.
  1. snarf
    Thread Starter Active Member
    Jun 7, 2007
    56
    As is posted in this Forum there are many sites from where one can find datasheets and component specifications.
    Does anyone know of any sites which gives a list of alternative equivalent components?
    All comments appreciated.
    Thank you.
  2. mik3
    Feb 4, 2008
    4,846
    63
    What component are you looking for?
    Some datasheets gives some equivalent components .
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    From the existing component, get a data sheet. Identify the critical parameters that have to be maintained. Do parametric searches on other manufacturers websites.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Mouser's website frequently lists alternatives for a component even if they don't stock the item.
    If you are desperate, you could go to NTE Inc's website and see if they make an equivalent replacement. Be prepared to pay anywhere from twice to 20 times the cost of the original component.
  5. snarf
    Jun 7, 2007
    56
    Thanks for reply.
    I’m not looking for any particular component at the moment but the information does come in handy when one can’t find what is needed.
  6. snarf
    Jun 7, 2007
    56
    Thanks for reply.
    Yes that is one way it could be done but I was thinking that maybe there are sites which gives the equivalent, maybe I am wrong.
  7. snarf
    Jun 7, 2007
    56
    Thanks for reply.
    I will have a look at Mouser’s web site, any other site that lists equivalents?
    NTE would be too expensive for me.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Mouser, Fairchild, and either Newark or Digi-key have parametric search engines.
    Once you determine the parameters of your original component, you can go into these parametric search engines, and start narrowing the search by selecting/entering various parameters.
  9. theamber
    Jun 13, 2008
    318
    You are looking for what is called a "semiconductor crossreference".
    If you want to save you may check the ECG,NTE,SK or globalspec website.
    It will show you lists of equivalent components.
    Companies like ECG build replacements and discotinued items like generic or similar ones from the originals usually cost a lot less than the originals but "may" not be as good.
  10. snarf
    Jun 7, 2007
    56
    Thanks to all for the valuable information.
    Anyone with additional recommendations are welcome.
