Here you go:They are line filter chokes. Can you post a picture of the otherside of what appears to be 2 Inverter units?
What is that little blue transformer that says 120v ?Thanks for that. Looking at the inverters they aren't quite the same as one has the speed control circuit in it & the other doesn't. But they appear to be tied so the frequency is in phase. So it should work with them wired in series to give 220V & 2x 110V ac. It must be cheaper to build 2 inverters than one large one!!!
There are no labels on that modules. I also thought that those modules control fan speed. Fans also doesn't have any label.The little blue transformer would get its 110v ac from inside that module to power circuits inside that inverter. What voltage is marked on the fans? & do these module vary the fan speed with differtent loads or internal temperatures?
I think that module converts some ac voltage to dc voltage for the cooling fans. What I am sure is that AC voltage does not come from the inverter modules.There are no labels on that modules. I also thought that those modules control fan speed. Fans also doesn't have any label.
You are right. Also the 12v outlet is running from the head.All inverter generators have separate windings in the generator head for running fans & 12v battery charging.
by Jake Hertz
by Duane Benson
by Jake Hertz
