Thanks debe. That's what I wanted to know . Don't worry about the wiring. That is the easy part. You clarified me how to have two 120v. Thanks again.I will assume you are in America as you refer to 4 pin sockets? Not something we use here in Australia. This is how it would be if you want 110v & 240V ac. Don't know how you would wire it up to the socket where you live.View attachment 81327
Probably I will conect the generator ground to the house metal screw of the drier socket external plate. That's what I think you are telling me.Cant realy give advice on wiring in America as its obviously different to how its done in Australia. Here in Australia the generator frame is connected to the earth pin in the socket only. There is no conection to any of the generator windings & here you don't connect the generator to any earth stakes. You will need to ask some one familiar with wiring codes in your area.
What you are telling me here that I will have is a 2750w, 220v genset?Since they have wired the inverters in parallel, you could try wiring them in series. This should give you 240V ac, but I would only wire it to through the 20A circuit breaker to the outlets. In series & doubling the voltage will give half the current available. Since they have wired the inverters in parallel then the frequency must be in phase.View attachment 81314
On ebay I could buy a 2 pole switch. They come from 10A to 30A. They are smaller than house breakers. Which one woud be the ideal one ? I could find them under " Marine Breakers".What you will have is 2 x 2500W 110V supplies. I would make one CB 20A & the other 10A to protect the supply when using 240V Not an ideal situation but you are trying to do something the generator wasn't designed to do.
I am asking because I don't understand if the amps are for each leg or the sum of each 120v.On ebay I could buy a 2 pole switch. They come from 10A to 30A. They are smaller than house breakers. Which one woud be the ideal one ? I could find them under " Marine Breakers".
Never mind. I found out. What I have doubt is about the size of the double pole I should use. I was thinking about a 15A or 20A. What do you think?I am asking because I don't understand if the amps are for each leg or the sum of each 120v.
Hi again debe.This should protect both inverters.View attachment 81409
by Duane Benson
by Jerry Twomey
by Jake Hertz
