How does decoupling capacitor provide necessary current with minimizing voltage drop of power line?
Discussion in 'General Electronics Chat' started by Dong-gyu Jang, Jan 15, 2016.
  1. Dong-gyu Jang
    Jun 26, 2015
    100
    Hello.
    I guess decoupling capacitor has two aspect of its working principle so
    1st is that it becomes shunt path from the power line to ground for high frequency noise. 2nd is that it is local energy storage to the active circuit like IC chip near to it so it provides necessary current when required but power supply is slow so can not response briefly.
    I guess the capacitors plays both roles at the same time.
    1st is easily understood. But I feel hard for 2nd. In order to draw current from the capacitor, according to I(t) = CdV(t)/dt, I(t) should be negative so is dV(t)/dt, means voltage must firstly be dropped. Is it conversational to 2nd aspects? In order to provide current, voltage drop on power line is inevitable?
    Maybe if C is large enough compared to required current, then voltage drop rate will be minimized and it is what 2nd aspect actually want to say.
    Could you please clarify my confusion?
  2. wayneh
    Sep 9, 2010
    12,371
    3,224
    In your mode 2, the cap is providing local power to the IC when that IC has a need for spike in current, for instance when switching an output. It reduces the noise that would otherwise be placed onto the power rail.
    You might say it has a single function to reduce noise from two sources, both the power rail to the IC and vice versa.
    Dong-gyu Jang likes this.
  3. Lestraveled
    May 19, 2014
    1,957
    1,217
    Another way to look at what a capacitor does, is its impedance or Xc. The higher the frequency of the noise, the lower impedance the cap will present to counter/reject the noise.
  4. crutschow
    Mar 14, 2008
    13,473
    3,361
    Yes, anytime the capacitor is delivering current its voltage has to drop.
    And yes, you make C large enough so that this voltage drop is acceptable for the circuit voltage and current requirements.
