How does an op amp with negative feedback featuring a transistor work?
Discussion in 'General Electronics Chat' started by trherzfeld, Feb 22, 2016.
  1. trherzfeld
    Jul 2, 2015
    8
    Hey, sorry for the basic question, but I was just curious on an op amp works when it feeds into a transistor and when it uses the emitter output as its negative feedback? Also, if R1 was the resistor/pot network seen, how would the pot affect the output? Any help/explanation is greatly appreciated, I'm just trying to understand how the circuit works. Thanks.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Q1 is configured as an emitter follower. It has a voltage gain of 1 and is non-inverting, so it has very little effect on the workings of the negative feedback loop. It also has current gain, so where the opamp output might be able to source only 20 mA into R1, Q1 as a power transistor could source over one amp.
    U1 is configured as a voltage follower, a non-inverting circuit with a gain of 1. This is used frequently to buffer a signal so that it can drive a larger load current. Basically, the voltage at the 1007 + input appears across R1 with much more current capability.
    ak
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    If "the output" is Vout shown in the left diagram, then it would have little, if any, effect. Vout is going to be within microvolts (or perhaps a millivolt) of the voltage applied to the non-inverting input of the op-amp.
  4. ian field
    Oct 27, 2012
    4,459
    792
    Its just a voltage follower - much like if you just took the op-amp output back to the inverting input.
    You lose the 0.7 Vbe from the available Vcc headroom, but it can source more current than the bare op-amp.
  5. crutschow
    Mar 14, 2008
    13,508
    3,385
    Basically the negative feedback means that the op amp will drive the base of the transistor such as to make the transistor emitter output equal the voltage applied to the op amp non-inverting (+) input.
    The effect of the 0.7V base-emitter offset is reduced by the open-loop gain of the op amp so, for example, if the open-loop gain of the op amp was 100,000, then this would appear as 0.7V / 100,000 = 7μV offset in the output voltage (negligible for most applications).
    cmartinez likes this.
  6. ian field
    Oct 27, 2012
    4,459
    792
    But you still have to subtract it from the available Vcc headroom.
  7. WBahn
    Mar 31, 2012
    18,089
    4,917
    Very true, but whatever output voltage you could achieve without the transistor (just the opamp) is now reduced by ~0.7 V -- that's the headroom that Ian was talking about.
  8. dannyf
    Sep 13, 2015
    2,196
    417
    The opamp adjust its output so that the output on the emitter equals that of the input.
    R1s value, within reason, does not impact the output, if you follow the reasoning above.
  9. crutschow
    Mar 14, 2008
    13,508
    3,385
    True. Never implied otherwise. ;)
