How does a current mirror behaving as active load in this circuit....
Discussion in 'General Electronics Chat' started by Himanshoo, May 17, 2015.
  1. Himanshoo
    Apr 3, 2015
    239
    6
    Ordinary resistor as load in a transistor amplifier has a certain short coming…we cant have voltage and current gain simultaneously …..means that if we need large voltage gain R load value should be very large ..and on other hand if we need high output current (Ic) R load value should be low..
    In this circuit a current mirror is actings as an active load in place of R load …I wonder how this current mirror able to give voltage as well as current gain at same time??
  2. JDT
    Feb 12, 2009
    658
    85
    The current mirror is a constant current source. Therefore it appears to have a very high output resistance. The voltage gain of Q1 is approximately RL/RE. So if RL is a very high value the voltage gain is high.
    Himanshoo likes this.
