How does a CMOS inverter work as an oscillator?
Discussion in 'Homework Help' started by Asmita Nayak, May 17, 2015.
  1. Asmita Nayak
    May 17, 2015
    9
    I know that it works as an amplifier in the transition or linear region. But how? What is the exact working operation? Please also explain in terms of i/o voltage/current?
  2. ScottWang
    Aug 23, 2012
    4,936
    777
    To search the V/I of IC from datasheet and using your keyword to google the circuit and explanation.
  3. WBahn
    Mar 31, 2012
    18,094
    4,920
    I take it you have a homework problem that is asking you to explain how a CMOS inverter can be used as an oscillator and wants you to explain it in terms of I/O voltage and current?
    You need to show YOUR attempt to answer YOUR homework problems. We can then use that as the starting point for guiding you through any misconceptions.
