How does a cell phone detector work and how to build one?
Discussion in 'The Projects Forum' started by gloface, Apr 15, 2007.
  1. gloface
    Apr 15, 2007
    Do you know those cell phone detectors that has LEDs that flashes when there is an incoming call? Something similar would be this pen that i found through google (the link originally provided expired, the redirection was to a suspicious site - moderator). I would like to find out how these work exactly and how to make one of my own.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. gloface
    Apr 15, 2007
    but what im having in mind is different. what i want is the detector that is able to convert the energy that is broadcast by the phone when it is active to light up the LED. In other words, it is operable without batteries.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Don't think there is enough energy available for such a device. A crystal radio can get just enough poop from an AM broadcast pumping out thousands of watts to drive a high impedance headphone. Your detector would have to build at least 1.5 volts and 2 - 5 milliamps to light a LED. The cell signal is in the milliwatt range.
  5. mozikluv
    Jan 22, 2004
    1,437
    i know what he is trying to imply. that led is the one used as backlight to keypads of a cellphone. this device is coated with rubberized plastic with an adhesive to be pasted at the back of the cp, near the antenna. but i have never given it a thought how its done coz its sold here at $o.o5 a piece only. so every time a signal comes in/out it lights up in a blinking fashion. some of those uses 3 - 4 leds so it looks like it dances.
    moz
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    They still don't light up without using the battery. There is just not enough RF Power to make it happen. If there was it would be heating up your eyeballs and other things as well.
  7. mozikluv
    Jan 22, 2004
    1,437
    papabravo, that device has no direct link to any supply. am attching a picture that device. i took it from my n70 cp cam
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Looks like fuzzy bowties. Crappiest pictures I've ever seen, and they prove what exactly?
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    They quite obviously prove the power comes from somewhere other than the bowtie.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    OK -- if you guys are convinced that power to light something can come from the ether it's fine by me, but I'll remain skeptical if it's all the same to you gentlemen.
  11. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Why would you believe we think the power comes from anethesia?:confused: The power comes from the cell phone's transmitter.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Whose power comes from where exactly? With an efficiency of what? Why not just connect it to the battery? Why mess around with such an inefficient scheme? This reminds me of a solution looking for a problem. BTW was I supposed to discern that from the pictures of the fuzzy bowties?
  13. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Its an after-market toy. Connection to the battery would require different configuations for different cell phones. Using the less efficient method, one size after-market toy fits almost all cell phones. Target market cares more about style and fasion than about efficient battery use.
  14. acidice333
    Feb 28, 2007
    I've got a antenna for my Nokia 5190/6190 that flashes when the phone is transmitting/receiving. Its old now, but I took off the antenna and put it next to my PDA phone and it still worked :)
