How does a 74LS47 works basically?
Discussion in 'Homework Help' started by zener_16, Feb 8, 2010.
  1. zener_16
    Feb 1, 2010
    9
    i read the datasheet of the 74LS47 but cant really understand how it works..
    i just know that it is a BCD to 7 Segment decoder..
    anyone can tell me more about 74LS47 function?
    Ty.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Which part of the function do you not understand?
  3. zener_16
    Feb 1, 2010
    9
    how does it works basically? A very general one.
    like why is it active-low at the outputs?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    7447 is is a simple IC that "converts" BCD code to LED 7-SEGMENT display.
    And 7447 is design to driving command anode LED displays. And that is why we have active-low at the outputs.
    http://en.wikipedia.org/wiki/Binary-coded_decimal
    http://en.wikipedia.org/wiki/Seven-segment_display
    And see the TRUTH TABLE
    http://maven.smith.edu/~thiebaut/270/datasheets/sn74ls47rev5.pdf
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Each segemnt of the display has associated with it a Boolean equation that determines weather the segment is on or off. For a single digit there will be seven equations, with each equation using four inputs. The equations can be written as a Sum of Products (SOP) or as a Product of Sums (POS) depending on which is easier to implement.
    Here is the important point. A decoder is a combinatorial circuit with NO memory elements.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
  7. nodoubtman
    Oct 21, 2011
    Hi! What's the difference between 74ls47 and 7447 ic??
    thank you!
    good evening!
    marC:)
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    Have you looked at the spec sheets of each? No better way to learn!
  9. tshuck
    Oct 18, 2012
    3,531
    675
    No doubt that this is a resurrection!
    Post a new thread if you need a question answered, not highjack a two year old one :D
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The LS device has less drive capability and the inputs represent a smaller load. It's all in the datasheet. Get them, read them, and appreciate them!
