how doe CD4017BE works
Discussion in 'The Projects Forum' started by placide, May 6, 2012.
  1. placide
    Oct 1, 2011
    22
    HI, can you please help me with full notes of how CD4017BE and what is contained it , it will be better if it is a pdf file.
  2. crutschow
    Mar 14, 2008
    13,503
    3,376
    Try this to start.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. placide
    Oct 1, 2011
    22
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    Perhaps gardening would be a better hobby. ;)
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The CD4017 is simply a sequencer. One output goes high with each clock pulse.
    The datasheet shows how to use it and shows the fairly low output current that depends on the supply voltage.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    You are in the wrong hobby my friend. Reading is pretty much required. Learning by example is also a good way to learn.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Then you're really gonna hate 1+1=10.:)
