How do you tell a capacitor is low ESR?
Discussion in 'General Electronics Chat' started by spinnaker, Dec 9, 2015.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,074
    1,176
    I have a datasheet that calls for a 10uf low ESR cap. How do you tell a capacitor is low ESR? Other than measuring it that is. Is there a marking that denotes low ESR? Or is it the cap type? For example the datasheet recommends tantalum as one of the types to use.
    What is considered a low ESR when measured?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Bordodynov likes this.
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    A low ESR capacitor will run cooler than a high ESR cap and as a result, will last longer. The chart above is out of date. Today's low ESR caps are down in the single digit milli-ohms.
  5. hp1729
    Nov 23, 2015
    2,097
    232
    Consult the manufacturer's data sheets for the caps.
  6. bwilliams60
    Nov 18, 2012
    734
    94
    Some of the better caps for low ESR are Panasonic, Rubycon and Nichicon. Watch for counterfeit caps, lots on the market.
  7. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    If a datasheet just says 'low ESR' without specifying a value, you are usually fine with any style of capacitor with a relatively low ESR. All this really means that you should avoid cheap unrated aluminum electrolytic capacitors, since their ESR is terribly high and can be several ohms.
  8. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    When buying caps stay with name brands and buy from a electronics company cause most parts on eBay are fakes and poorly constructed.. Don't get me wrong I have alot of parts from eBay that work great but just understand the risk involved .. Do a search on mouser for low esr caps..
