how do you read ascii schematics?
Discussion in 'General Electronics Chat' started by mecha, Nov 10, 2012.
  1. mecha
    Nov 10, 2012
    18
    Hello - newbie question - some folks post schematics in ascii - I can't make them out - any tips?
    thanks!
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Any examples?
  3. crutschow
    Mar 14, 2008
    13,462
    3,353
    Are you referring to .asc files? Those are not ascii, they are LTspice files. You can download the free LTspice simulator program from Linear Technology to look at those files and also simulate the circuits in the files.
  4. vk6zgo
    Jul 21, 2012
    677
    85
    No,they use the ASCII characters to actually draw a circuit diagram,a bit like
    people used to make pictures using teletype machines years ago.
  5. kubeek
    Sep 20, 2005
    4,686
    805
    Reading that requires non-proportional font like terminal or courier, then the drawing should make more sense.
    Do you have any examples you have trouble with?
  6. spinnaker
    Oct 29, 2009
    5,062
    1,159
    Then what do you mean by "read" them? Just look at them.
    I have never seen anything like this.
    Once again do you have an example????? I physical example?
    If a schematic was produced by a teletype machine, why should you can about reading it anyway? The technology in the schematic would be extremely outdated.
  7. kubeek
    Sep 20, 2005
    4,686
    805
  8. spinnaker
    Oct 29, 2009
    5,062
    1,159
  9. atferrari
    Jan 6, 2004
    2,663
    783
    Horrible drawing. Those things should be forbiden by international law.
  10. vk6zgo
    Jul 21, 2012
    677
    85
    I said "a bit like"--got to be careful with "speed reading"!:D
  11. Blofeld
    Feb 21, 2010
    82
    18
    Exactly. The easiest thing that works for me is to copy the stuff into Notepad (I'm pretty sure every PC running Windows has it - don't know about Linux).
    In Notepad it looks OK. I'm not saying it looks nice, but that's impossible to achieve.
  12. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You read them like any other schematics. It often helps to look at it from a distance of a few feet first. That will give you the overall picture, then you can look closer to find the details.
  13. mecha
    Nov 10, 2012
    18
  14. MrChips
    Oct 2, 2009
    12,622
    3,451
    Yikes!
    At the very least, use Paint or hand draw your drawings and post a photo or scan.
  15. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Okay, that looks like an archive, and it appears that the circuits have lost their spacing. Without spacing, it's impossible to know how the circuit is supposed to be connected.
  16. mecha
    Nov 10, 2012
    18
    thanks, I don't feel so stupid now :)
  17. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Hahaha, yup. There's absolutely no way to read that unless you can figure out the original spacing. Sometimes it's possible, but it's rare. You're perfectly fine :p
  18. ScottWang
    Aug 23, 2012
    4,923
    776
    To using the ascii chrs to draw the circuit, I think that idea is came from ascii art as below:
    http://www.google.com/search?hl=en&...urce=og&sa=N&tab=wi&ei=u8OeUIjuEersmAXdooCYBg
    Some systems of the forums will reduce the space automatically, so you can not use or not easy to draw the circuits.
    For some reasons that the people will use ascii chrs to draw the circuits, some are for the HDD space of the website, some are don't like to draw the circuit by paint or as protel, oracd etc.
  19. WBahn
    Mar 31, 2012
    18,065
    4,904
    It displays fine on my browser. As others have said, it is important to get the intercharacter spacing correct. If the maker used a fixed-pitch font and nothing reduced multiple whitespace to a single space, you should be able to render it properly.
    In this particular schematic (which I realize you are just using as an example) there is a connection that doesn't make sense -- namely the emitter of the NPN transistor. I'm guessing there is a resistor to ground that is missing.
  20. spinnaker
    Oct 29, 2009
    5,062
    1,159
    My thoughts. Why would anyone post such a thing? I see from Scott he says to save space plus a few other ideas but yikes!. It has to be a hassle to create and even a bigger hassle if the spacing goes away.
