When I go to use a new part on a schematic, I usually re-orient the pins so they are oriented on the schematic part as they are oriented on the PCB.
When it comes to parts with high pin counts such as MCUs, this helps me plan what pin of the MCU to connect to which component.
But I am seeing where this technique can be time consuming reorienting the part put might not make for the best layout when it comes to the schematic.
How do you orient you component pinouts on the schematic?
I was using Express PCB but I have moved to Diptrace recently.
