how do you make a preset toggle ff like in a 4029 decade counter?
ian field
Joined Oct 27, 2012
6,536
My 4029 is fried and I want to make the same type of flip-flop that it has.
thanks!
Search archive.org - they have some very old Signetics applications books for various logic families.
There are many pages of detailed logic diagrams of what's in a lot of MSI logic blocks.
tavish
Joined Nov 12, 2014
8
thanks for not being sarcastic. I did try Google, that's how i found this website.
I already have schematics.
34,470
What do you mean by "make the same type of flip-flop"? Do you want a replacement counter chip, individual FF chips, or make it with discrete transistors?
ian field
Joined Oct 27, 2012
6,536
"sarcastic"?! - tell me what you've been smoking, I want some.
You're not the first to give a nasty reply when I've tried to help - this forum has some odd rules, none of which weed out the idiots!
tavish
Joined Nov 12, 2014
8
Oh, I didn't mean make them, I just wanted to know what type of flip-flops were in it. My schematic only shows them as boxes.
Papabravo
Joined Feb 24, 2006
21,228
Generally speaking unless otherwise indicated the flip-flops represented by boxes in MSI (Medium Scale Integration) chips are D-type flip-flops. Other possible types are the T (Toggle), the SR (Set-Reset), and the JK flip-flop.
The Toggle flip-flop can be made from a D-type flip-flop by connecting the Q_BAR output to the D-input. The Q output will change to the opposite state on each clock edge.
For how flip-flops are made from gates, checkout the following
https://www.google.com/search?q=Fli...v&sa=X&ei=9bxmVIXjNYT4yATWqIC4BA&ved=0CB0QsAQ
tavish
Joined Nov 12, 2014
8
Thanks, it's a counter and say TE, PE, and P. these are the only inputs besides the clock, so I think it's a toggle. I mainly need to know what the TE does because I'm going to make a stem-step schematic. I'll try the link.
oops. meant step-by-step.
Yay! found out it's not fried. Still want to know about the FF's though.
ian field
Joined Oct 27, 2012
6,536
I was thanking you for not being sarcastic like the other guy. I'm a kid.
Its fairly usual for someone to *BE* sarcastic when they reply to someone they think is being sarcastic - your opening line looked like that.
Popular Electronics did occasional tutorials on logic circuits as they emerged onto the market late 60s/early 70s.
I downloaded the magazines from electronicsandbooks - but the site seems to be offline when I just tried it! Although it sometimes takes a few goes to log in at the best of times.
Assuming you get there, you can navigate the folders for a load of other magazines - but you'll need a big hard drive.
tavish
Joined Nov 12, 2014
8
Thanks, but my schematics don't show all those inputs, nor do I know what most of the new ones do.
I don't put words together well. My hard drive is almost full but i'll see how far I get.
I'm not good at putting words together. my hard drive is almost full but I'll see how far I get. thanks!
nope. couldn't handle it.
