how do you make a not gate?
Discussion in 'General Electronics Chat' started by ranch vermin, May 24, 2015.
  1. ranch vermin
    May 20, 2015
    85
    just <snip> talking.
    so if i apply power to a semiconductor, i can then negate the resistance.
    But then ive just added power to power, how do I make power where there isnt power?
    I cant go generate power where there isnt, I end up just nullifying power or granting power where there isnt, unconditionally.
    How does PNP and NPN work?
    I have a garbage solution, and double the bus and have a separate line for true and false both powered.
    But doubling the complexity of the (factory) recurser, is a bad idea.
    Dont think I think im coming up with anything new here, I KNOW all you already know how im fumbling.
    Mod edit: no cussing.
  2. Alec_t
    Sep 17, 2013
    5,948
    1,129
    Just stick 'em in a circuit and apply volts :p.
    Recycling?
  3. ranch vermin
    May 20, 2015
    85
    Hehe, just blow a 128 bus on a 64.
    yeh... so i make my <snip> hardware creation software, negative to positive, add the 100% automatic practical resistance thermal algorythm to create the bitmap footprint, dedicated to so many metres squared, multilayerd to 1 square cm, (2c worth of metal), but how the hell do i get it out here for real out of the physically correct program... optical printing?
    and thats only after i made the frozen method robot to make the die.
    think i cant do it, man!
  4. crutschow
    Mar 14, 2008
    13,462
    3,353
    I believe the OP is off his meds. :rolleyes:
    DerStrom8 likes this.
  5. ranch vermin
    May 20, 2015
    85
    dont worry ill implement soon. im just working on the algorythm i want to custom put in the hardware.
    I dont care if it never makes it to real metal, ill be wippin so much <snip> by then why would i give a <snip>?
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    as for the title of the post, just add an inverter to the output of an and gate.
  7. ranch vermin
    May 20, 2015
    85
    thankyou but ill back off and just read from now on, i dont know enough yet.
