How do you increase transmitter range?
Discussion in 'General Electronics Chat' started by Robin Mitchell, Dec 22, 2010.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    HI everyone,
    How do you increase the range of a transmitter? (radio)
  2. shteii01
    Feb 19, 2010
    3,516
    515
    To quote Tim the Tool Man Taylor: More Power!
  3. Robin Mitchell
    Oct 25, 2009
    738
    207
    seriously :p
    So i would use a transistor to amplify the signal going into the transmitter?
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    In most cases, you use transistors (and/or tubes) to amplify the RF signal from the transmitter. Sometimes, the least expensive way to increase range is to use a bigger antenna, a higher antenna, a more efficient antenna, or a directional antenna.
    What frequency are you transmitting? What is your present power output? What antenna are you using? If you're already running the legal limit for the frequency you're using, then improving your antenna is your only option (and even that may not be legal.) On the other hand, if you're currently running well under the legal limit, an additional amplifier may be the answer.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Exactly, what frequency are you dealing with? It's easy enough to look up the legal ERP.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The range can also be increased by using a directional antenna.
    That will point the power in one direction.
    Also a dirctional antenna at the reciever side may help.
    What frequency range are you using?
    Check how much power you may use in that range at the local authorities .
    Take a look at this page for antenna ideas:
    http://ac6v.com/antprojects.htm
    Bertus
  7. Kermit2
    Feb 5, 2010
    3,854
    968
    The other way that won't make the FCC freak out, is to increase the receiver sensitivity. Bigger RCV antenna or a higher gain RF amp section, or both.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Select the right band. RF propagation can be around the world on the right band. Check ou the Space Weather site for MUF (Maximum Useable Frequency)
    http://www.spacew.com/www/realtime.php
  9. solis365
    Member
    Nov 5, 2008
    21
    if you're trying to boost the range of those car FM radio transmitter thingys, look up the "itrip." terms like itrip hack, itrip mod, etc
    all they do is make the antenna bigger.
    ive been looking into doing this and thats the easiest solution. the other way is to get a stronger FM transmitter IC or build your own, which is significantly more complicated.
