This is the Danelectro Honeytone practice amp circuit. Diodes D1 & D2 are 1N4148 silicon ones. I measured a sine wave output on the oscilloscope and this is what i found:
1) with both diodes REMOVED: pk-pk voltage=5.7V
2) with 1N4148 diodes intact: pk-pk voltage=2.88V
**These voltages were measured at pin1.**
Everyone says they are clipping diodes. I think that too. But, if the diode's forward voltage drop=0.7V, then 2X diodes should be 0.7x2 = 1.4V? Shouldn't the pk-pk voltage with diodes intact be more than 2.88V? Just a little confused here..
