How do you display pictures (schematics)?
Discussion in 'Feedback and Suggestions' started by Chris Wright, Aug 26, 2006.
  1. Chris Wright
    Jul 26, 2006
    62
    Iv'e tried using the "[​IMG]" command (without the quotes), but it won't work:
    Iv'e tried the "img src=" html code:
    <img src="http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=222">
    <img src="http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=222.jpg">
    can anyone tell me what I'm doing wrong?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Click on the FAQ link that is located in the tool bar along the top of the forum page and search on the keyword "attachment" without the quotes. I think that will help you out. If you still are having problems let us know.
    hgmjr
  3. Chris Wright
    Jul 26, 2006
    62
    Help, I'm locked in a loop I and I can't get out [​IMG]
    I started at the FAQ and it said to use the "" code
    So I did (see original post) and it didn't work
    So I posted a question
    and the answer sends me back to the FAQ which tells me to .....wait I smell a loop! [img]http://forum.allaboutcircuits.com/images/icons/icon7.gif
    Seriously, I have already uploaded attachments but they don't "Display". I had seen images displayed in threads so I knew it could be done and I figured the "" code or a line of html would do the trick but neither worked. Interestingly the icons above displayed fine using the "[img]" code. So what's the trick?
    [img]http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=222.gif
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The tags "" (in capitals) should work to give you an attachable image, for example:
    [ IMG]http://www.orbisnap.com/vrtdesc/matlab.jpg[ /IMG] (without the spaces) gives:
    Can you try this and let me know if this works? If not can you provide a link to the relevant schematic to see if I can get it working?
    Dave
  5. Chris Wright
    Jul 26, 2006
    62
    Ahh....Caps! it's case sensitive. I should know better, but I've gotten used to a site that is not case sensitive. Sometimes It's the forest for the trees. Thanks!
    Wait,...... wait! I spoke too soon. No It's not case sensitive. I just displayed your image using lower case "" code. But this does narrow it down a bit. Your URL displayed and mine did not. It does tell us that there is a unique requirement that the URL must meet in order to be displayed. Some sites require the URL to end in ".jpg" or ".gif" but I have tried both. (my hosting site will serve up the image with either ending or none at all)
    Both links below are surrounded (in caps) by the same code that displayed your image below (in lower case).
    Test Display from image hosting site:
    [IMG]http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=222
    [ IMG]http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=222[ /IMG]
    Test Display for uploaded file:
    Spaces added to force code to disply: [ IMG]http://forum.allaboutcircuits.com/attachment.php?attachmentid=168&d=1155968521[ /IMG]
  6. jrap
    Administrator
    Jun 25, 2006
    966
    202
    I believe the problem is that the image you are trying to link to is outputted through a PHP script. vBulletin seems to not allow this (security reasons I would think?)
    If you save the image locally, then upload it to an image hosting service it should work.
  7. Chris Wright
    Jul 26, 2006
    62
    The image is already on a hosting service, but thanks for the try. I see you didn't get it to work either, it still came up as a link. The only difference is that your hosting service provides a thumbnail to use as a link instead of the plan text link. I think you are right, it doesn't like the PHH script some hosting services use for serving up the images, including the one you tried to use. With this in mind, I tried a picture from my "home page" that was in the usual form: "Host/directory/directory/image.jpg" and it displayed fine just like Dave's image.
    Here is another try in the usual form- It works, I think we have it! [​IMG]
    Thanks again all!
  8. Firestorm
    Jan 24, 2005
    353
    Do the smilies not work? :)
    -guess they do, just wondering while there were close to 10 links for the smiley...wierd :(.
