Do you have a circuit with this Piezo buzzer to post here. .png is preferred.so how do i control the duty cycle?
Uhhh, yeah.A piezo beeper (it beeps at a high frequency, it does not buzz ......
I don't buy this. The diaphram only makes sound when it is moving. Regardless of the duty cycle, the diaphram moves twice each cycle. The only way to vary the sound intensity (okay, not the ONLY way, but from a simple driving signal standpoint) is to either increase the amount of the deflection or increase the speed of the deflection. The first involves applying a greater voltage while the second involves driving it with a lower impedance to reduce the RC time-constant involved. I would think that controlling the voltage is the more practical way for most simple circuits.So, to summary, what is the purpose of the duty cycle in our case ? The volume ! You can vary the volume of the sound by modifying the duty cycle. 0% will produce no sounds, 50% will be the max volume. Between 50% and 100% is the same as between 0% and 50%. So, when I say when need a constant duty cycle, it's not that true, it's just that we'll set it at 50%, so the chances we hear something are high
by Aaron Carman
by Aaron Carman
by Jake Hertz
