How do you connect LDR sensors with a PIC ??
Discussion in 'General Electronics Chat' started by zeeba, Oct 3, 2010.
  1. zeeba
    Sep 26, 2010
    22
    Hi
    Im writting a code to read from both LDRs and show the reading on LCD and I want to see if it's working
    but I dont know how to connect the LDRs with the PIC?? ​
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. timrobbins
    Aug 29, 2009
    318
    16
    Sounds like you're using the LDR for an analog signal, rather than as a digital input??
  4. tom66
    May 9, 2009
    2,613
    214
    If your chip has them, you will need to use the comparators or an ADC input. Then put a resistor in series with an LDR to form a divider; connect the resistor to the PIC's Vdd and the LDR to ground. The centre tap between these points is proportional to light levels.
