how do u dissolve
Discussion in 'The Projects Forum' started by scratch, Oct 4, 2011.
  1. scratch
    Aug 6, 2010
    38
    Pls does any one know of a way to dissolve cured epoxy.
    THANKS
  2. Kermit2
    Feb 5, 2010
    3,851
    966
    Judging by what it does to epoxy paints; Brake fluid might soften it given sufficient time.
  3. Darkstar
    Sep 3, 2010
    104
    Dissolving cured epoxy is not easy. It requires a fairly concentrated solution of potassium hydroxide in water. The epoxy is immersed in the solution and it is boiled until the epoxy gradually dissolves. If the epoxy has a filler in it such as silica, forget it. To dissolve the silica requires an acid so you would have to alternate between acid and base. I had to do this once at work and had to have an identifiable IC in the end. It took hours to dissolve just a microscopic layer, so it was not feasable to do.
  4. KJ6EAD
    Apr 30, 2011
    1,426
    363
    There are plenty of methylene chloride based epoxy removers available. Jasco and Attack are two.
