i want to know that how to they select the value of resistors in amplifier circuits!for example " http://www.flickr.com/photos/aj_silverthunder/3817569935/ " in that schematic u can see R,R3,R4 resistors,they resist voltage to the transistor,but on what reason they select the value.what will be the result if a low value resistor is used instead of R,R3,R4, and
what if higher value is selected,what will be the result,on what parameters of the transistor do they select the value! please explain me
