How do resisters develop a signal?
Discussion in 'General Electronics Chat' started by Dclapp, May 19, 2013.
  1. Dclapp
    May 18, 2012
    I am trying to understand audio amplifiers. I keep a running across words to the effect that a particular resistor "develops" a signal. I have no idea what this means! Help?
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    That's a bit of an odd way to phrase it, although there are some contexts in which it would be pretty natural.
    When you pass a current through a resistor, there will be a corresponding voltage across it. In some circuits you take several signals that are in the form of currents and sum them together and then send the total current through a resistor in order to get a voltage that is proportional to the sum of the individual signals. You can do similar things to get signals that are proportional to the difference of two signals, as well.
  3. Shagas
    May 13, 2013
    802
    74
    If you were reading about the common emitter BJT amplifier , then when you have a collector resistor and the transistor starts conducting (it's resistance goes very low) then there is a current flowing through the collector resistor which means that a voltage generated across the resistor .
    Think of the collector resistor and the transistor as a voltage divider (that's what it really is )
  4. Dclapp
    May 18, 2012
    Excellent, Shagus. Thank you so much.
