HOW DO I USE OP AMP?!
Discussion in 'General Electronics Chat' started by leonkoh, Jan 18, 2009.
  1. leonkoh
    Jan 18, 2009
    hellos, im a electronics student and currently im doing a project about making a car. those small ones. and i need to add special features to the car. which im thinking of using op amps. i have a voltage source of 5V and 3V. but i dont know how to use the op amp to produce sound or how to make the schematic diagram (multisim). i think i need to record sounds. but im really at a lost. can anyone HELP ME?! :(
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you help us a bit more? The cars you speak of are not very well described by just "those small ones". If it is too small, then circuitry and a speaker just won't fit inside.
    Tell us more about the sounds, too.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. Søren
    Sep 2, 2006
    472
    28
    Too bad nobody fix or remove dead links from that page :(
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    If any link is dead, you can try to look in the past with "the wayback machine".
    http://www.archive.org/web/web.php
    Copy the url of the link in the search line and press "take me back"
    This will produce a page with dates the page still was available.
    Click on one of the dates and you will get the page of that date.
    Greetings,
    Bertus
  8. russ_hensel
    Jan 11, 2009
    820
    47
    It is a Wiki, so you could fix.
  9. mik3
    Feb 4, 2008
    4,846
    63
    To record sound you need to use ADC and memory chips to store it digitally. Then to reproduce it you will need a DAC and an amplifier to drive the speaker.
    Describe the project better.
  10. Søren
    Sep 2, 2006
    472
    28
    Sure, I've been using it for many years, but it usually doesn't store PDF's etc.
    Besides that, my point was, that it is sloppy to not keep your links up to date and it makes the entire site look bad - after all, you can automate the checking procedure with programs made for the purpose, so the only real work is repairing links (or remove them).
    Russ_Hensel <- Sorry, I don't see any reason to enroll in every other guys site to do the work that they should do (have done) themselves. Certainly not a site so confusing to navigate.
    That site needs a serious make over to be useable to folks like me.
