How do I turn a relay on and off with 2 individual momentary switches?
I have an arm that will swing down and land on a momentary switch (we shall call this the "On Switch"), that will trigger the relay and turn on the motor. The motor will rotate the arm back into position. When the arm is fully upright, the bottom on the arm will hit another momentary switch ("Off Switch), that will trigger the relay and turn the motor off.
It is important to note that the "On Switch" should not be able to turn off the relay. Visa Versa, the "Off Switch" should not be able to turn on the relay.
