how do I switch 12v with 556
Discussion in 'General Electronics Chat' started by JayK026, Feb 26, 2012.
Thread Status:
Not open for further replies.
  1. JayK026
    Feb 26, 2012
    12
    I'm using a 556 timer. Side A is a one-shot, side B is a an astable multi-vibe combination.
    A 2.5-3 sec pulse cycle then output remains high until power is removed. Need this circuit to switch 12v via p channel mosfet witch requires neg input(right?) But the circuit output is pos. I don't know how to accomplish this. Logic gate? Help pleeeeze, thanks.
  2. k7elp60
    Nov 4, 2008
    479
    69
    Not haveing a schematic of your circuit here is an idea. The NPN transistor such as a 2n3904 inverts the signal and when the collector is in saturation the P-channel mosfet is turned on.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Your PMOS is upside down, and you definitely don't need negative feedback from drain to gate (the 100k) when making a switch.:(
    JayK026, if I understand you correctly, you want the PMOS to be on when the 556 output is low. If this is correct, and your 556 is also powered by 12V, then connect the 556 output to the gate of the PMOS, the source to +12V, and the drain to your load, which I assume is grounded on the other end. If you are using a CMOS 556, then that's all you have to do. If you are using a bipolar 556, then you will need to add a resistor (1k should work) from the 556 output to +12V, because the output high level of the bipolar 556 will only go to about 10.5V, which is not high enough to guarantee that the PMOS is off.
    If you want the PMOS to be off when the 556 is low, then you will need an inverter after the 556, as suggested by k7elp60.
  4. JayK026
    Feb 26, 2012
    12
    Thanks for the responses, I should clarify my needs. So 12v is applied to the 556, at the same time 12v is ready to be switched through the pmos, the 556 output will ge high at this time. So the inverter would b the best option for this?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    This should work.
  6. k7elp60
    Nov 4, 2008
    479
    69
    As always Ron is correct. I was away from home on a trip with my laptop
    and a while after I posted my reply I thought I forgot to invert the PMOS.
    The 100K was susposed to be from the gate to source, to insure cutoff when the inverter wasn't on.
    Thanks for the correction Ron.
    JayK026 likes this.
  7. JayK026
    Feb 26, 2012
    12
    Well, it works now! Switches 12v, I have this hooked to a brake line circuit. Works great when the vehicles ignition is on, but when running it dosn't function prop. Not sure why,
    Some kinda interference? Any ideas?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    When the engine is running, you are using what is probably the noisiest power supply you will ever work with. :(
  9. JayK026
    Feb 26, 2012
    12
    Is that the issue I'm having...if so how can I isolate this circuit?
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Can you tell us what the load is, and how much current it draws?
  11. colinb
    Jun 15, 2011
    351
    35
    Is there a decoupling capacitor on the 556? You might also add a ferrite bead to the power input and possibly a second cap to form a pi-filter. Maybe you need to regulate down to 12 V or less -- your charging voltage may be much higher than you expect. Measure it.
    JayK026 likes this.
  12. JayK026
    Feb 26, 2012
    12
    Load led lights, 3.8 watts. Circuit is on motorcycle. Two separate switches, front and rear. While engine is running.... The rear brake switch triggers the circuit so it flashes 6 times then remains solid until released.
    The front brake switch triggers the circuit but it only flashes once then remains solid. If I press the rear switch, then the front switch before the circuits cycle is through the tail light goes solid. The tail lights
    Share the same input wire. Maybe a faulty wire in the front switch?
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Motorcycles are also considered as automotive modifications.
    Bertus
Thread Status:
