How do I record multiple messages onto an ISD1100 Chip?
Discussion in 'The Projects Forum' started by corner_boy, Nov 12, 2008.
  1. corner_boy
    Thread Starter Active Member
    Jun 24, 2008
    36
    I set a up a topic earlier about my capstone and a voice tone but my problem now is that I need to record multiple messages onto the chip.There are a few set ups in datasheets available that i have looked at but not one has given me that certain way of setting it up. Since im trying to have the chip be activated with binary outputs, does anyone know how to set the chip up to have multiple messages?any advice would be helpful thanx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The datasheet I just glanced at has that information. The "real" datasheet is a .pdf file about 957 Kbytes long.
    You record to different segments of memory, selectable by address. Playback works the same way. The limit for total message length is 12 seconds.
  3. corner_boy
    Jun 24, 2008
    36
    wheres the link so i may look at it
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    You can go to www.datasheetarchive.com and search on isd1100.
    There are other places but this should give you what you need.
    hgmjr
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    If the datasheet is old and it was scanned, then a big file has more tears (the torn tears or the crying tears) and more ketchup and mustard on it.
  7. corner_boy
    Jun 24, 2008
    36
    i was looking through the the data sheets and, besides the basics of it, i couldn't grasp the concept of how to record multiple messages. Maybe i just need a little more assistance from someone who's used it before in this manner because the sample wiring i believe is only used for short record and playback.
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    corner boy,
    ISD1100 has 10 seconds for recording time, divided into 80, binary addressable segments. By setting certain address lines high during record, and again during playback, you can record and play back specific segmants. I did this with an ISD1400 (40 seconds) several years ago.
    I have a three page document "Stand-Alone/Parallel interface Products: Basic Addressing" Chipcorder Technology by ISD, that includes the ISD110 addressing. If you don't have it I'll try to post it.
    Ken
    Kenechif likes this.
  9. corner_boy
    Jun 24, 2008
    36
    please post it up for me, would really appreciate it
    ****edited**
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    What do you need us to post for you?
    hgmjr
  11. KMoffett
    Dec 19, 2007
    2,584
    234
    hgmjr,
    Check my previous post. :)
    Corner boy,
    The document is at work and I'm at home today. I'll try to scan it and post it tomorrow.
    Ken
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is the data sheet from the original manufacturer for you to look over until kmoffett can post his document.
    hgmjr
  13. KMoffett
    Dec 19, 2007
    2,584
    234
    cornor_boy,
    Thanks for the ISD1100 manual.
    Attached are two zipped app. notes for the ISD chips. ISDAdd.zip (6 pages) is the app. note on Addressing. ISDAmp.zip (2 pages) is the app. note on adding an LM386 audio amp chip.
    Hope this helps. :)
    Ken
  14. Kenechif
    Oct 1, 2015
    Thanks for the files but does the isd require further programming before recording
  15. WBahn
    Mar 31, 2012
    18,085
    4,917
    Don't hold your breath waiting for an answer from a thread that died more than seven years ago.
