Ok.. so I have this homework to build a multistage amplifier using 2 common emitter, 1 common collector amplifiers with 20V DC, 10mVpp ac input, and 20 Ohm load resistance. The goal is to have 60dB output. I tried to make the q point as close to 10Vdc as possible across all amplifiers but I always end up with distorted cut signals with low output(in orcad). The 20 Ohm load condition seems impossible to satisfy because it severely decreases output gain(if it doesn't burst into flames). Is there a way around all of this or any organized step for building it? Or any methods that I should be aware of?
