How do i make an ultra sonic border detector (ARDUINO, ZUMO)
Discussion in 'General Electronics Chat' started by olliemax1, May 17, 2016.
  1. olliemax1
    Apr 26, 2016
    I need to make a Zumo that roams a track ( the track is tape on a table, black tape ) and uses an ultra sonic component to detect where to go and stay with in the bounds.
    It would be best if i could only use 1 sensor.
    Can any one offer any help/resources such as code, example systems, etc?
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Welcome to AAC!
    If the Zumo is constrained to follow the tape, won't that keep it within bounds? I'm puzzled as to why you'd want an ultrasonic sensor in addition.
  3. GopherT
    Nov 23, 2012
    6,304
    4,027
    The ultrasonic sensor is used to identify the competitor or an obstacle. It is not used to follow black/white line on a board.
    Use the reflectance sensors for that. Infrared light (IR) is absorbed by black and reflected by white so you can easily tell whether or not you are on/off the line as you monitor the sensors.
    https://www.pololu.com/product/1419
    It should be included in your kit.
