How do I make a 4 volt 2 watt battery pack?
Discussion in 'The Projects Forum' started by Coastersplus, Aug 5, 2012.
  1. Coastersplus
    May 31, 2012
    I am making a robot with 4 transistors and 3 resistors. But for the circuit to work, I need 4 volts and 2 watts. How would I connect batteries to get that?
  2. cork_ie
    Member
    Oct 8, 2011
    348
    58
    6V battery with a LM317 regulator adjusted to 4.0V is about the easiest way I can think of. It is quite possible your circuit will work directly off 3AA cells in series (4.5V)
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Most things that say 4 volts don't mean 4.00 volts or I'll blow up. Then there are a lot of people that have an LED labeled 4 volts maximum and they blow it up because they won't tell us what they are doing and they don't know that LEDs care about current, not voltage.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    Three NI-CAD or NI-MH will be 4.2V - 3.7V over their full life.
  5. crutschow
    Mar 14, 2008
    13,526
    3,393
    How long do you need this 2W to last?
