What was the other one?I'm not saying I've never done that, but you seem to have a run going today.
Battery charger. I think it's Dr. Killjoy. You advised about a lithium battery long after OP said it was lead-acid.What was the other one?
Couldn't find any mention of that in the OP and I skipped a few of the replies.Battery charger. I think it's Dr. Killjoy. You advised about a lithium battery long after OP said it was lead-acid.
All the local stores have dropped the larger incandescent bulbs, and some are offering halogen capsules assembled in regular BC bases with a glass globe surrounding the capsule - so they look superficially just like regular bulbs.I like the idea of changing the bulbs to 25W. While it reduces the maximum luminosity available, since you were dimming the 40W bulbs anyway, it may be adequate.
If you keep getting steamed up about things as trivial as that - you'll end up driving yourself potty!@ian field
http://forum.allaboutcircuits.com/threads/lm317-issue.112936/
Your post #18
My post #19
"Not quite exactly tailored to the original question"?
If you don't think side-tracking the Thread with irrelevant information is, "bad", then I disagree with you.
IMO, Misdirecting the TS is almost like hijacking the Thread into a different topic.
You label misinformed advice as; "hijacking a thread" - and that's not getting emotional?!!!@ian field
You think I'm having an emotional moment?
I thought I was having a very calm conversation.
In the future, I will simply refer these irrelevant posts to the Moderators.
That will remove my alleged emotions from the equation.
Yes, that was the option the OP decided to use.Did anyone mention making strings of two 40W bulbs in series. Then only 20W for each two bulb string string.
Ken
