How do I keep a LED glowing constant from a variable DC voltage
Discussion in 'The Projects Forum' started by rigerman, Mar 29, 2016.
  1. rigerman
    Apr 25, 2014
    40
    My problem is to keep a LED glowing constant as the output of my circuit varies from 2.9V to 10V. The LED now glows according to the output voltage. I would like to keep it glowing constant. I have tried using LM317T but, for the range 2.9V to 3.7V, the LED remains off as LM317T needs a min voltage of 3.7V at Vin.
    Any suggestions?
  2. rigerman
    Apr 25, 2014
    40
    I think I need around 2.1v constant at LED pin no matter what the output voltage is. (2.9 to 10) Is there any sort of regulator for it?
  3. crutschow
    Mar 14, 2008
    13,497
    3,373
    You can use a low dropout regulator, such as the LT3080 (350mV dropout), in a constant current configuration (see data sheet).
    KJ6EAD likes this.
  4. Dodgydave
    Jun 22, 2012
    5,153
    770
    You could use a Jfet constant current circuit, but your led will need 2.1v and the fet or regulator will need 1v.
  5. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Here's a simple circuit which will give the appearance of a reasonably constant light. In this example, the LED current varies from about 9mA-12mA for the 2.9V-10V input range specified.
    rigerman and KJ6EAD like this.
  6. crutschow
    Mar 14, 2008
    13,497
    3,373
    Here's a two transistor variation of Alec's circuit, which has the advantage of better regulation.
    Its minimum voltage drop is <0.8V.
    The current varies from 9.6mA to 10.7mA over a 2.9V-10V input range with a 2.2V LED, which likely will give very little change in the observed brightness.
    The nominal current is ≈ 0.67/R1.
  7. rigerman
    Apr 25, 2014
    40
    Thanks. It works!
    I am having a slight problem with the V at 2.9v. The LED dims down significantly. I measured the voltage at it's pins. It is around 1.43V. My output voltage also drops at times to 2.3V which might be causing the issue.
    I will provide some more feedback once I stable the output voltage.
  8. RichardO
    May 4, 2013
    1,339
    429
    You never said what kind of LED you are using. For instance, a red LED might only need 1.7 volts to light to maximum brightness. A blue or white LED might take as much as 4 volts to be at full brightness. Other colors of LED's require different voltages.
  9. mcgyvr
    Oct 15, 2009
    4,791
    975
    aka see the "forward voltage" rating in the datasheet of the specific LED you are using
  10. crutschow
    Mar 14, 2008
    13,497
    3,373
    What is the voltage at the collector of the transistor when the input voltage is 2.9V?
  11. dannyf
    Sep 13, 2015
    2,196
    417
    The 2.9v can be hard to hit, depending on the leds used. A jfet CCS or a CCS-built off a LDO may be your best chance.
    Or a boost converter.
  12. rigerman
    Apr 25, 2014
    40
    My output voltage is dropping to a stable 1.9V. So if I can provide around 1.85V to the LED constant, I think the glow will be stable. The V range is 1.9V to 10.1 V.
  13. crutschow
    Mar 14, 2008
    13,497
    3,373
    Below is a CC circuit that requires a minimum operating voltage of only about 0.2V above the LED forward voltage to operate, which is likely about as low a dropout voltage as is practical.
    It uses a low voltage op amp that will operate down to 1.2V, single supply, and has a built in 0.2V reference.
    The two 10kΩ resistor dividers reduce the reference voltage to 100mV , giving a constant-current of 100mV/R1.
  14. rigerman
    Apr 25, 2014
    40
    I am sorry for the delayed reply. I will test the circuit (I do not have the opamp in my arsenal), and feedback.
    Thanks a lot for your time...
  15. John P
    Oct 14, 2008
    1,638
    225
    It seems simplest to just make the circuit's output turn on a transistor, and use it as a switch to power the LED from some other source.
