I recently came across a LCD display and an Advantech single bord PC and Now I want to Identify the LCD panel in order to get some data on the panel to match it up with the small PC for car use (or just playing with it for fun ?).
I Googled all the codes found on the device but no luck, it seems that it is a 5.7" 320x240 CSTN panel, the only info I have on it is that it should be a Batron BT 30 001 but I can not seem to find any data on it.
It has inverter and LCD driver board attached, if anyone can help I appreciate it, any info is appreciated.
Thanks in advance, Peter
