I don't understand your question.The voltage? Which node? Where is the ground reference (I assume the bottom of the schematic.
The voltage at the node between R1 and R2 will be different than the voltage between R1 and R2 (when switch is open).I don't understand your question.
I'm asking about current.The voltage at the node between R1 and R2 will be different than the voltage between R1 and R2 (when switch is open).
What point in the circuit do you talk about when you are asking for voltage?
Do you see red I, I want to discuss about current after switch is closed? Immediately after closing.Ok, at which point in the circuit do you want to discuss? You have parallel and series in this circuit. Current will not be equal everywhere. So, what point are you interested in?
No.Hello there,
So you want the current through the switch then, and is the polarity the same as that arrow?
I ask because the normal conventional current flow would be down not up, but either way is ok as long as you understand the difference.
My question is, do you know how to calculate the steady state current or cap voltage BEFORE the switch is closed? That is, assuming the 100ma current had been flowing for a very long time. That would be the starting point.
Then assume the capacitor is not there
Total resistance is R1||(R2+R3).Then assume the capacitor is not there
So, first step is to calculate the
Series resistance of the one parallel leg.
Then calculate the total resistance seen by the current source.
, and then do the calculation of the voltage at each node.
by Jake Hertz
by Duane Benson
by Jake Hertz
by Aaron Carman
