How do I edit my blog?
Discussion in 'Feedback and Suggestions' started by Wendy, Jun 9, 2015.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    I noticed some links had changed, so I went in to correct them. I don't see any way to edit my blog, but I have to figure I'm missing somethin obvious?
  2. jrap
    Administrator
    Jun 25, 2006
    967
    202
    The blog add-on is not most intuitive software, that's for sure.
    Since you are using the old design here is a screenshot with it:
    Then click the "Description" icon and it should pop-open an edit box.
    Rob
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I try to edit the description section and I get the following error:
    The following error occurred:
    Please enter a value using 800 characters or fewer.
    My index is quite large, I could break it up into smaller chunks, but 800 characters sounds pretty small.
  4. jrap
    Administrator
    Jun 25, 2006
    967
    202
    Hmm I think that limited is hard coded by the blog software - I'll see what I can do.
    Are the links that were broken pointed towards AAC? I thought I had properly redirected all of the old URLs. If you come across any that don't redirect please let me know!
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'll work around, as I can. 800 characters sounds small, but then I'm spoiled.
    The link in question is the Battery University, evidently they relaid their site out, and I need to adjust.
    Thanks for trying.
    Push comes to shove I could use other means, such as a locked thread, for the index.
