How do I connect to this chip?
Discussion in 'The Projects Forum' started by bumclouds, May 18, 2009.
  1. bumclouds
    Thread Starter Active Member
    May 18, 2008
    82
    Hey guys,
    I have a really small IC that I need to make connections to for a uni project. I would like to put it into a breadboard or similar, so that I can build circuits around it.
    The only trouble is the spacing on it is so tiny!! The whole IC itself is about the size of the fingernail on your little finger.
    Here are the dimensions for it. Is there some kind of a socket or something I could utilize? I've been looking but I cannot seem to find one!
  2. kubeek
    Sep 20, 2005
    4,691
    806
    No sockets for these.. If you really want to go without proper PCB, you can for example bend every other pin up and the rest down from the socket, and connect some enameled magnet wire to them. But it won't be anywhere near the reliability of a chip soldered to PCB directly.
  3. bumclouds
    May 18, 2008
    82
    I found a socket that looks like it might work...
    It's a whopping AUD$237/USD$180 though. Why is it so exp?
    EDIT: Ahh I found another one.. for 19 bucks..
    Will this do the trick?
    Specs
    SMD ADAPTOR, SSOP 650/650UM
    Length / Height, External:32/50mm;
    Thickness, Board:1.6mm;
    Diameter, PCB Hole:1mm;
    Connector Type:SSOP;
    No. of Holes:56;
    Material:Epoxy Fibreglass FR4;
    Thickness, Copper:35µm;
    Link to data sheet.
  4. DonQ
    May 6, 2009
    320
    11
  5. bumclouds
    May 18, 2008
    82
    zomg that's exactly what I need.
    Thankyou so much!
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    Lets hope that your soldering skills are good. I've known many good Techs and Engineers that had the soldering finesse of a blind welder that just drank a gallon of coffee! :D I had a friend (long ago) that built a Heathkit that he asked me to look at because it didn't work. When I opened it I exclaimed... "You have a short and a cold solder joint"!.. He said.. "Where"?... I said... "Everywhere"! :eek:
