I am looking at buying a battery pack like this, or this. If you can't open the links, those are simple Li-ion battery packs (11.1v and 7.4v respectively).
Which will be charged with this "smart" charger.
But for charging my phone/other things, I was thinking of using this UEBC (is it just a switch regulator?).
But how do I connect them so that when I get home I can plug the battery pack into the charger, and when I'm on the road I can use the switch, without having to move any wires around? I'm assuming there is a very simple way of doing this, but since I have never touched a circuit before...
I am happy to read anything in the circuits guide that you point me to, as I have done so before and found it very helpful.
Should my first question have been whether or not I can even use that switch with my battery to charge a cell phone? I just figured that since it says its output is 5v and 4A I should be good.
