How do I check in LTspice if I have met the specification in the question?
Discussion in 'Homework Help' started by Kai Chiang, Sep 2, 2016.
  1. Kai Chiang
    Oct 27, 2015
    12
    With reference to this diagram
    Single-stage CS amplifier with CSL
    In LTspice I believe it looks like this
    I am not so sure how do I check if my circuit met the specification in LTSPICE
    1) Open-loop gain: > 50
    2) Output voltage swing: > 1.2 Vp-p
    3) Supply current: < 500 μA
    4) DC Output voltage is 1.5V
    What should I key into LTSPICE to check?
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,573
    522
    You move your cursor to the Vout terminal and click. That gives you the waveform after you do a simulation run. That will tell you the DC voltage and AC voltage so you can calculate the gain too.
  3. Kai Chiang
    Oct 27, 2015
    12
    Hi
    When I click run , I am not really which analysis I should use.
    There is transient , AC analysis , DC sweep , Noise , DC transfer and DC op pnt.
    If I want to find out the Vout of the voltage swing in LTspice, how should I go about? I know that the voltage can swing up 2.1Voltage and down to 0.9voltage since output voltage is given as 1.5V.
    also which function should I use to check the gain of the circuit?
  4. MrAl
    Jun 17, 2014
    2,573
    522
    Try both transient and AC and see if you can get some results.
    For example, in AC you may be able to tell right away with the gain is.
    In transient, you can look at the peaks and figure out the amplitude, then divide by the input voltage peak to peak for example.
  5. crutschow
    Mar 14, 2008
    13,523
    3,391
    Transient analysis is a time-domain analysis which calculates the actual voltages at all nodes using the models for the devices (most of which are generally non-linear).
    It can only calculate results for one input frequency or waveform at a time.
    The AC analysis is a frequency domain analysis which calculates the DC operating point and then linearizes the device gain based upon that bias point.
    It can only have a sinewave (AC) as its source.
    It then generates a frequency and phase response for the selected output node over the selected frequency range, using these linearized models.
    Since this is a frequency domain analysis with linearized devices it makes no difference what the source AC voltage is as far as the relative gains are concerned.
    But 1V is typically used for the AC source since then that corresponds to 0dB in the LTSpice calculations.
    The output response in dB thus directly corresponds to the gain in dB from the input to the output.
  6. KaiL
    Member
    Aug 30, 2014
    61
    Hi Thanks for your reply.
    I would like to check if my circuit is correct in LTSPICE with reference to this
  7. KaiL
    Member
    Aug 30, 2014
    61
    Not sure why it is only in 0.6V range ?_?
    By right it should be the voltage should go up 2.1Voltage and down to 0.9voltage since output voltage is given as 1.5V. Did I do something wrong?
  8. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Because you don't have the right values for R1,W,L?
    That is the target you are being asked to achieve with your circuit design. Try varying the component values/properties.
  9. KaiL
    Member
    Aug 30, 2014
    61
    But is my circuit correct with reference to this?
  10. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Don't know. All the FETs in my sims have 3 legs; not 4 :).
  11. KaiL
    Member
    Aug 30, 2014
    61
    I see. The fourth leg is about Body source which i ground it as shown in my circuit diagram in LTspice. Thus, no body effect.
  12. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Shouldn't the substrate connection of the top FET go to the +ve rail rather than ground?
  13. KaiL
    Member
    Aug 30, 2014
    61
    Why? Actually , I am not so clear about this ?_? I only know that if you connect it to ground , there will not be any body effect. I maybe wrong though since I have just started on MOSFET lesson.
  14. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Because it's a P-type?
  15. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Perhaps this will help.
  16. KaiL
    Member
    Aug 30, 2014
    61
    I see. Thanks
