How do I calculate firing angle of single phase RL circuit?
Discussion in 'Homework Help' started by fazlio, May 19, 2009.
  1. fazlio
    May 19, 2009
    Hi. How do I calculate the firing angle of single phase ac/ac full wave if i am only given resistive load 1.5 ohm, Vs 120v, 60 Hz and oP 7.5Kw? Thanks Guys
  2. jasperthecat
    Member
    Mar 26, 2009
    20
    fazlio
    Try googling "thyristor firing angle"
    I got this first up
    www.reseeds.com/thyristor%20control%20question.doc
    The question only mentions a resistive load not a RL circuit
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    There is no "simple" way of solving this but it can be done numerically.
    If the power at firing angle 0 degree is Po and the power at firing angle α is Pα
    then it can be shown that
    Pα/Po=k=1-α/Pi + (1/(2*Pi))*sin(2α) [with α in radians]
    Since you are given Pα=7500W and you can work out Po (thereby giving you the required value of k) you can then solve for the value of α using some numerical approximation technique (or graphical method) or a programmable calculator (if you have one) might have an equation solver function.
  4. fazlio
    May 19, 2009
    Great! Thanx a lot guys!! Cheers!
