How diode is passive component?
Discussion in 'General Electronics Chat' started by CIR.VINIT, Mar 2, 2016.
  1. CIR.VINIT
    Feb 26, 2016
    11
    diode also control flow of electron.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A passive componet is one that one that is incapable of amplification. A device needs a minimum of three terminals to do amplification.
    CIR.VINIT likes this.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    To be and active device it has to have the ability to take power from some source and provide power amplification to the signal.
  4. CIR.VINIT
    Feb 26, 2016
    11
    I agree,but in active component electricity is able to control electricity.In diode forward-reverse bias characteristic is giving me an intuitive idea of electricity is able to control electricity.???
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    How so? Because the current through the diode is controlled by the voltage across the diode?
  6. CIR.VINIT
    Feb 26, 2016
    11
    ok then,so let me call it a VCD (Voltage Control Device).VCD is also an Active device.hence Diode is Active device????
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    By your line of reasoning, a resistor is an active device -- after all, the voltage across it controls the current through it. Or, equivalently, the current through it controls the voltage across it.
  8. SLK001
    Nov 29, 2011
    852
    243
    Not really... a two terminal device can amplify.
    nsaspook likes this.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    It should be pointed out that there is no universally agreed upon and unambiguous definition of what constitutes and "active" versus a "passive" device. Furthermore, the definition is context-dependent and distinguish between DC and AC behavior. You can easily find lists that say a diode is active (apparently just because it is a semiconductor) and others that say it is passive.
  10. CIR.VINIT
    Feb 26, 2016
    11
    hmm,you are right sir,but my intention is not to prove a resistor a active component.I just want to know that if according to the definition of active component, active component electricity is able to control electricity.In diode forward-reverse bias characteristic is giving me an intuitive idea of electricity is able to control electricity.???or every component R,L,C Etc in some sense we control electricity is able to control electricity.
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    The real question is what, exactly, do you mean by "electricity is able to control electricity"?
    Keep in mind that any meaning that could be used to say that a resistor (or other clearly passive device) is an active device is automatically a meaning that cannot be used to say anything about whether any device is active or passive.
  12. CIR.VINIT
    Feb 26, 2016
    11
    I have just started to learn about electronics,i am sorry if somewhere i interpret your answers incorrect. Truly saying,now i am totally confused what people want to say diode is active or passive?or we can't say any thing about this?and how?
    i learn all this from http://www.allaboutcircuits.com/textbook/semiconductors/chpt-1/active-versus-passive-devices/
    plz crystal-clear it.
  13. nsaspook
    Aug 27, 2009
    3,016
    2,375
  14. CIR.VINIT
    Feb 26, 2016
    11
  15. WBahn
    Mar 31, 2012
    18,087
    4,917
  16. CIR.VINIT
    Feb 26, 2016
    11
    WHAT I CONCLUDED .....IS
    Diode are Passive elements(as you guided me,wiki too, etc) but on the basis of small signal modal where small energy stored is not negligible they came into category of Locally active component called as active diode.
    I feel its all depends on the way we look into the reality of nature and trying to compromise it with human made artificial definitions....
    thank you.....
  17. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Look, you know what a diode does, don't bother with arbitrary definitions that don't really help in any meaningful way.
    Just accept the standard definition so other people know what you are talking about and move along.
  18. SLK001
    Nov 29, 2011
    852
    243
    My definition of a passive device is one that only consumes power (attenuates the signal) and doesn't alter the signal. By this definition, a diode is definitely active, since it significantly alters the signal.
  19. WBahn
    Mar 31, 2012
    18,087
    4,917
    By that definition capacitors and inductors are also active devices.
  20. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    A tunnel diode only has 2 leads...........................
