how connect Parallel or series fluorescent lamp
Discussion in 'General Electronics Chat' started by minh, Oct 2, 2011.
Thread Status:
Not open for further replies.
  1. minh
    Nov 24, 2010
    24
    Dear All
    I have an shemas 9 watts fluorescent driver (please see picture), and 2 tubes lamp 4w only.
    Could you show me how connect 2 tubes :
    _ Parallel or serial
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you tried to connect them either way, your driver would still be too much power for the tubes, and they would have a short life.
    If you connected them in parallel, the current through the tubes would not be balanced unless the driver was designed for that; so one tube would burn out very quickly.
    If you connected them in series, the voltage required to ionize the tube would double; the tubes may not light at all.
    You need to match the proper driver(s) to the tube(s).
    minh likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    Bertus
Thread Status:
