How come plugged in transformers don't consume power?
Discussion in 'Power Electronics' started by Amit Ika, Jul 4, 2016.
  1. Amit Ika
    Jul 4, 2016
    10
    Hey guys,
    This has boggled my mind for a bit: How come a plugged in transformer does not consume power? Here's a link to a circuit diagram of a phone charger:
    http://circuitdigest.com/sites/default/files/circuitdiagram/Cell-Phone-Charger-Circuit.gif
    Obviously as its plugged in, the primary coil circuit of the transformer is completed with the wall which means ac power is flowing through it regardless of whats going on with the secondary coil. What am I missing here? Is it consuming power if it is plugged in and not used? Any clarification would be great!
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Of course it consumes power.
    The primary or other SMPS device is presenting a load, albeit small to the service power supply.
    Max.
  3. Amit Ika
    Jul 4, 2016
    10
    So then how does a plugged in phone charger that is not connected to a phone not consume power? I mean plugging it in to the wall is basically shorting the circuit. Is it not?
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    It most definitely is not.
    A transformer with no load is not a short, instead it presents a high impedance (high inductance) to the line.
    Why would you think it's a short?
    For an ideal transformer the input power equals the output power so, no output power equals no input power.
    A real transformer has some small loses in maintaining the magnetizing inductance so it will draw a small amount of power (typically a few percent of its rated power).
    Suggest you read up on how transformers work.
  5. BR-549
    Sep 22, 2013
    2,181
    419
    They do consume power. I recall a study, that concluded saving a ridiculous amount of power by unplugging wall-warts.
  6. dannyf
    Sep 13, 2015
    2,196
    417
    an ideal transformer is essentially an impedance transformer: it "maps" the secondary windings impedance onto's the primary side. An unloaded transformer has an infinite impedance on its seconday winding. Thus infinite impedance onto the primary winding -> no power consumption.
    In reality, a transformer isn't perfect so it does consume a little bit of power, even when unloaded.
    Amit Ika likes this.
  7. Amit Ika
    Jul 4, 2016
    10
    The reason I think it's a short is because one end of the primary coil is in contact with one terminal of the outlet and the other end of the primary coil is in contact with the other terminal of the outlet. I understand that there is an impedence but is that really enough to prevent the power consumption of a short? Also this then means that a primary coil with low impedence will act as more of a short. Is this not true?
  8. nsaspook
    Aug 27, 2009
    3,014
    2,368
    How about a tiny bit of deductive reasoning. Transformers are plugged into the power grid everywhere, the power grid has not been shorted out because of these transformers. So what would make you think an unloaded transformer is a short?
    Metalmann likes this.
  9. Kermit2
    Feb 5, 2010
    3,852
    967
    Actually, for a very short period of time (microseconds) the transformer is just a piece of copper wire.
    Once current flow starts a magnetic field is established in the iron core.
    This creates a "resistance" to current flow. This kind of resistance is called impedance.
    It is the magnetic field that prevents the short circuit you are envisioning
  10. hp1729
    Nov 23, 2015
    2,098
    232
    It does consume some power, just no where near as much as when in use. The key is the characteristic impedance of an inductor. Impedance changes with the density of the magnetic field which depends on the current. As it starts drawing current impedance decreases so primary current increases. (in 100 words or less)
  11. DGElder
    Member
    Apr 3, 2016
    347
    87
    It is not a short for the same reason an inductor across and AC voltage is not a short. The current into the coil is inversely proportional to the frequency of the AC signal and the inductance, 1/(2*pi*f*L). Since a transformer has a very high magnetization inductance the current through the primary coil, with the secondary coil open, is quite small. And most of the energy that goes into the primary is returned to the mains since an inductor can not dissipate energy, just momentarily store the energy and return it to whence it came. There will be small IR losses due to resistance in the wire, magnetization of the core and eddy currents, so a few watts will be lost as heat.
  12. Amit Ika
    Jul 4, 2016
    10
    Thank you all for your replies! This makes a lot more sense now.
  13. nsaspook
    Aug 27, 2009
    3,014
    2,368
    To the OP please read this:
    http://www.allaboutcircuits.com/tex...chpt-9/mutual-inductance-and-basic-operation/
    Metalmann and Amit Ika like this.
