How can I upgrade/develop this circuit to become more effective, efficient and complex.
Discussion in 'The Projects Forum' started by E/E Engineering, Apr 15, 2016.
  1. E/E Engineering
    Apr 15, 2016
    My circuit is a automatic laptop cooler. I have try to add two more comparators in to the current circuit where each comparator lights a colored LED when a certain temperature is sensed, however i tried, but did not work for the reason i do not know how to combine them together. another idea was when a certain temperature is senered they will be a fixed voltage and they will be three LED with 3 fixed voltage, that come on when that certain temperature hits. e.g. 25ºC will be 5v which will light up LED 1 and 35ºC will be 8v which will light up LED 2, however this was too complex and did not work.
    I will appreciate any help or advice and thank you for reading this.
  2. wayneh
    Sep 9, 2010
    12,388
    3,245
    LM3914
    E/E Engineering likes this.
  3. E/E Engineering
    Apr 15, 2016
    senses analog voltage levels and drives LEDs
  4. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Add some hysteresis to the comparator.
    The relay is not required; use a suitably rated transistor to drive the motor directly.
  5. Dodgydave
    Jun 22, 2012
    5,154
    772
    Use a Lm35 temperature sensor and lm3914 bargraph chip, more linear response better than a thermistor.
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    Might I encourage you to challenge the assumption that "upgrade" and "complex" ever belong in the same sentence.
  7. SLK001
    Nov 29, 2011
    851
    243
    Add hysteresis and a high side P-channel MOSFET to replace the relay.
