Hi
I have some camping 'round style' LED arrays that consist of 20 LEDs in parallel and no external resistors in circuit. These operate from 4 AA batteries and have fantastic light output. I want to connect two of these lamp arrays together and run from a deep cycle 12v (14v) battery in my van. To experiment, I pulled two LEDs out of the lamp array and series connected to the 12v battery and this resulted in their early demise. Prior though I ran each from the 4 AA 6v supply with no problem!
Rather than setting up a regulated 6v from the 12v deep cycle and wasting precious power from regulation, can I series connect the 2 lamp arrays together and perhaps use a zener to control voltage to each and not waste any power in the process? My design knowledge is limited but I thought the wasted power that is generally accepted from voltage regulation could be used for the second lamp array. If this is possible will the zener waste some voltage resulting in too low a voltage? Essentially I want to split a 12v supply into two 6v supplies without drilling into the battery (expensive AGM) or by using DC-DC convertors. I fear connecting the two lamp arrays in series further destroying the remaining LEDs.
Appreciate any knowledge on this.
