I am repurposing an old home ventilation fan to just preform extraction, but its too powerful and loud. I need to reduce the speed by about 25-30%, doesn't need to be variable. Its a PSC motor, do i need to increase the capacitance?
Indeed not: http://www.designnews.com/document.asp?doc_id=221517The normal AC blower type motor is not friendly for simple or inexpensive speed change tricks.
Ummm... No.Its a direct drive axial fan, i think i can maybe add a choke, trying to find out now what value in Henrys of choke to use for a 100W 230V motor.
This leads me to believe that i could use a choke, and that it likely has been used in manufacturing plenty. Id say it has died out as a method of speed control as you need a large lump of copper to make one.Ummm... No.
If it was that easy, you would see this trick used everywhere.
You are asking the motor to revolve at a different speed / frequency than it's designed to operate, AC motors like this cannot be controlled so easily.
The only reasonable way is to use a VFD, that's gonna work, but its way more expensive than a new fan...
wont reducing the voltage increase the current? Ohms law and all? Resistance is constant, voltage drops, current increases?If it's direct drive fan with a shaded pole or split capacitor type (most common on fans) reducing input voltage will reduce speed without causing motor problems.
V = I * Rwont reducing the voltage increase the current? Ohms law and all? Resistance is constant, voltage drops, current increases?
BTW It is not an axial fan, it's known as a Radial type.Its a direct drive axial fan, .
Also known as a squirrel cage or centrifugal fans.BTW It is not an axial fan, it's known as a Radial type.
Max.
Actually withe permanent split capacitor motors regardless of whether they are multi speed or not they tend to take triac phase angle control of their speed rather well. It's been done many times.You are not going to control a furnace fan with a Triac controller, it was done in the past with a multi-winding motor,
by Duane Benson
by Jake Hertz
by Aaron Carman
by Duane Benson
