how can i protect against overvoltage on 12Vdc
Discussion in 'General Electronics Chat' started by bobrock, Nov 30, 2004.
  1. bobrock
    Nov 30, 2004
    I am tryin to find out how i can protect my LCD monitors in the car from an overvoltage . max voltage is 12V and im sure its 13.5 or so when charging.
    will a rectifier work ??? or a regulator of some type?? :blink:
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    usually the LM7812 will do the trick, but if you very particular that the voltge does not exceed 12v, this regulator has an output tolerance of +/-5%. so chances are it would still exceed the 12v, but i don't think the 0.6v extra would affect your gadget. :)
  3. IanP
    Nov 18, 2004
    5
    The 7812 regulator is not very good for this.
    For it to give you 12V you need another 3V.
    You should rather use low dropout regulator LT1086-12 (V0ut=Vin+0.5) or switchng regulator such as LMLM2575-12.
  4. IanP
    Nov 18, 2004
    5
    You should rather use low dropout regulator LT1086-12 (Vin=Vout+0.5) or switchng regulator such as LM2575-12.
  5. bobrock
    Nov 30, 2004
    thanks for your time guys ......... im gonnnnna research it and see where i can find them
  6. bobrock
    Nov 30, 2004
    P.S. you guys are really smart ! thx again
  7. ram
    Dec 3, 2004
    you can use a32-tnt relay oto protect from over voltage more than 0.12 volts
